on 08-08-2023 10:42 AM
I'm afraid I'm unable to hear anything on my landline phone due to severe crackling. The phone is unusable. I've had something like this recently but it's much worse now. Rain seems to make things worse. My internet is also intermittent at times. I've done the checks suggested elsewhere with no result. The crackle starts as I pick the handset up even with a different handset. The crackle is on incoming as well as outgoing calls. I think it must be the external line. Please help.
on 08-08-2023 11:32 AM
I'd just like to confirm where my responsibility for equipment begins and yours ends. I have a "junction" box where the line comes in from outside. Then that is connected by a wire to the plug socket into which my phone and line filter are plugged. My question is - if my responsibility is after the "junction box" then perhaps I could check the connecting wire? If it's after the plug socket then I think I've checked all I can.
on 08-08-2023 11:26 AM
Found it thanks. You should have all requested
on 08-08-2023 11:14 AM
Hi EKG62
If you click on your Community username/avatar at the top right of the page then you should see a small envelope icon, the message will be there.
on 08-08-2023 11:13 AM
Where do I find the PM please?
on 08-08-2023 11:12 AM
Hi EKG62
Once you have completed the form I've sent in the Private Message and we have confirmed security then we can book an engineer visit to take a look.
on 08-08-2023 11:10 AM
Checked again. Still crackling and internet has been down for a short time.
on 08-08-2023 11:08 AM
Hi EKG62
Ok thanks for confirming this.
The next step will be an Openreach engineer visit to the property as the line tests are clear.
Thanks again.
on 08-08-2023 11:07 AM
Yes indeed. I plugged the second handset in directly
on 08-08-2023 10:55 AM
Hi EKG62
The line tests are clear, no faults detected.
When you tested with a different phone was this directly at the test socket with the router removed from the line?
