on 10-11-2024 10:42 AM
We found yesterday that the landline is not working although the broadband is fine. No calls in or out. No dial tones. No ringing.
on 14-11-2024 09:56 AM
That's great new Treborth, thanks for letting me know 🙂
on 14-11-2024 09:32 AM
Hi Chris,
We have just been called on the landline by Openreach to tell us the problem has been fixed.
We now have a working phone.
Thank you so much for your help in setting up the repair and for getting it done so quickly.
Excellent support again from you and your colleagues.
on 13-11-2024 11:53 AM
I've raised this to Openreach, they will investigate over the next 72 hours and may contact you directly if they need to access your home
on 13-11-2024 11:47 AM
OK thanks, I'll raise this to Openreach for further investigation
on 13-11-2024 10:45 AM
Hi Chris,
Yes I can confirm there is still a fault.
on 12-11-2024 07:13 AM
Hi Treborth,
Can you just confirm that it's still not working and we'll arrange an engineer visit
on 11-11-2024 09:46 AM
I have just tested with the test socket and there is no change with the current handset.
on 11-11-2024 09:37 AM
Good Morning, Michelle,
Thank you for getting in touch.
We do not have a second handset so cannot test this.
I will test the current handset with the test socket.
on 11-11-2024 08:40 AM
I'm sorry to hear this. I've run a test on the line now which has detected a potential fault. Can I just confirm, is the no dial tone fault also present at the test socket with 2 different handsets? As soon as we have confirmed this then we can raise this over to Openreach for further investigation.
