Home Phone
VOIP not working
mazin1
Message 16 of 16
Is there a national problem with talktalk's VOIP? That is what I was told when called the support desk last week. I can't see anywhere where talktalk are communicating with customers and giving them an update on this issue. can anyone advise?
15 REPLIES 15
Message 1 of 16
Good morning,
I'm really glad to hear this and thanks for letting me know 🙂
Message 2 of 16
Hi Michelle
Just to let you know VOIP has started working as of today. Its all very odd as I have done nothing at this end and the replacement grandstream box has yet to arrive. Somebody must have tweaked something.
Mazin
Message 3 of 16
Hi Mazin,
Thanks for the update and we'll also check back in with you after this date to see how you're getting on. I've also included our auto compensation policy below,
About your auto compensation credit - TalkTalk Help & Support
Message 4 of 16
hi Michelle
Thanks for following up. Yes the team did call today. The VOIP issue is still unresolved. They are sending out another grandstream box just in case that is the problem, which will be another 3 to 5 days to arrive. I have been promised  a call after Christmas on 26th to see if it is working with a new box. Fingers crossed it does the trick but I am not convinced it will.
I have had no land line since 11 December which has been extremely inconvenient. I would very much appreciate your advice  on how I best go about getting some compensation or goodwill gesture from Talktalk.
Mazin
Message 5 of 16
I believe that my colleague has now made contact. Please let us know how you get on.
Message 6 of 16
Apologies, I will chase the team for an update now.
Message 7 of 16
hi Michelle
No news? Nobody has contacted me.
I am finding the experience with TalkTalk customer service quite frustrating  : (
Mazin
Message 8 of 16
Thank you. I've escalated this straight over to our Faults Escalation Team now and I will post back here as soon as I receive an update. It's possible that the team may also try and contact you directly.
Message 9 of 16
Hi Michelle
I have updated my profile.
Mazin
Message 10 of 16
Thank you for trying this.
  • Name
  • Telephone number/account number
  • Alternative contact number
Message 11 of 16
Hi michelle
Yes it is a grandstream. I have switched the device of from the power, reconnected it and then  reset the factory settings with a pin but no joy. the blue light for the phone line does not come on.
Can you please escalate as I have so far had 2 calls with tech and no joy. I wonder if my account has been set up properly?
Many thanks
Mazin
Message 12 of 16
Morning mazin1,
There was an outage last week but this has now been resolved. Can I just confirm, are you using the Digital Voice Adapter (Grandstream) please? Could you try resetting the DVA again please, holding the pin in until the leds on the top start blinking simultaneously. If there is no change following this then let us know and we can pass this straight over to our Faults Escalation Team for you.
Message 13 of 16
yes still a problem ! have tried resetting etc. The call centre said a problem with all vOIP?
Message 14 of 16
Hi mazin1
Apologies for this.
Can I just confirm, is this fault still happening this morning?
Gliwmaeden2
Message 15 of 16
There was an issue during the week, @mazin1.
Staff will reply during the week.
I'll move this to the home phone section. On there it might be worth you reading the posts on the subject, with tips for resetting equipment etc.
