Home Phone
digitise
nosliw
Message 5 of 5
I use a pendant alarm - can you tell me when you are digitising my area SL8 5NL
4 REPLIES 4
Message 1 of 5
A direct message. Thanks.
Message 2 of 5
what's a DM?
nambuso-TT
Message 3 of 5
Hi there @nosliw I've sent you a private message. Please refer to your DMs. Thanks
Message 4 of 5
Unfortunately TalkTalk probably don't know but you would be contacted befotehand and will then have a chance to discuss your needs.
If you have special requirements you will not be transferred to full fibre until those needs are met.
Have you registered as vulnerable? If not I'd recommend you check this page and do so.
https://community.talktalk.co.uk/t5/Articles/Registering-your-accessibility-requirements/ta-p/258302...
