Home Phone
landline extension phone
bmbmbm1
Message 2 of 2
Just had fibre 150 via eero6 installed and existing old wired house phone connected to digtal
voice adaptor So far all is well except that we have lost use of extension phone in bedroom which was also wired. Can I install a Panasonic kxt tgc digital phone or similar on eero6 and use it as my extension phone along with old house phone. If so how would I connect them so as they would be paired and work in conjunction.
1 REPLY 1
Divsec
Message 1 of 2
Hi @bmbmbm1 I'd be tempted to start again with a dect phone, I recall they support 5 wireless extensions.
The new phone would have an answerphone included and connect to the digital Voice adapter.
From the 29th of March our TalkTalk Community will move to peer-to-peer support and the TalkTalk team will no longer be here to support with queries. Don't worry we still have plenty of ways to reach out if you need to speak to TalkTalk directly. For more details check out the link here: How to contact TalkTalk Broadband - Help & Support. 03451720088
