Home Phone
phone
yellowk
Message 4 of 4
Is there any way i can get incoming caller name display on the phone.
3 REPLIES 3
Message 1 of 4
Good afternoon,
As advised, I think this would depend on the type of handset you have. Do you have the Caller Display service set up in your My Account?
Message 2 of 4
If you have caller display enabled on your landline account you should get the number phoning you showing.
Is your phone showing this?
Does your phone have an address book? If so adding people to this with their phone number should display the person calling.
Numbers not in your address book cannot show the name of the caller.
Divsec
Message 3 of 4
Hi @yellowk depends on your phone and whether the incoming caller is in your contacts on the phone.
If the caller is unknown the best you can hope for is the caller's number.
