Online security
Get answers and information about our security products.
WiFi device unsupported for security or software updates.
Mazzie52
Message 9 of 9
I have just received an email which states that you contacted me recently to advise that my WiFi device was now unsupported and would not receive further security or software updates. The email also states that I have the option to purchase a new device at only £60. Generous to a fault, you also said that there would be no P&P charges.
So my query is, when you sell my type of contract, you provide a new device. So presumably the cost of this device is included in the cost of the contract. I have no recall of the advice given at the time of purchase to tell me that when the device dropped out of the 'supported' range, I would not automatically receive a new device - I would have to pay for an updated model.
Why is support for the device not included in the contract if you have provided said device when the contract was signed?
Yes, I do understand that the technical support is provided by the manufacturer but if the device was to fail/ become faulty before the support from the manufacturer has ended, you would provide me with another device. Why does the same criteria not apply when the device is no longer supported by the manufacturer?
And Yes, I understand that the device is not necessarily faulty and security may be okay so it is probably  okay to keep it but that is not the point, is it? If you are going to send out warning emails that the device is no longer supported by the manufacturer, surely there should be an option that you send out a new device which is not outdated. I could still refuse the new device and opt to keep the old one if I was satisfied with its performance but currently, my options are - keep the old device and hope it is safe or pay £60 for a new one.
Not satisfactory customer service.
8 REPLIES 8
Message 1 of 9
Can you please confirm your address in private, thanks.
Message 2 of 9
Thank you for confirming, please bear with me as I check on your account.
Message 3 of 9
Thank you for your reply.
My account number has been entered.
Message 4 of 9
Hi there @Mazzie52, please update your details on your community profile such as your account number and/ landline number so we can be able to locate your account and assist further, thanks.
Message 5 of 9
Thank your for your response. My current contract ends in August 2026. Although I am aware that if the router becomes faulty it will be replaced foc, that doesn't address possible security issues - the router could be working but security could be breached because of lack of security updates.
I will wait until the contract is nearing its end and consider the options available to me then.
Of course, if, in the meantime, security is breached, further words will be spoken!
Message 6 of 9
Good advice from @fr8ys exactly where I was leading with my question about your contract. If you are currently not in contract look out for Black Friday deals!
Message 7 of 9
Its a regulatory message that has to be sent in the event of devices becoming unsupported.
If the router becomes faulty and after testing by tech or support staff it would be replaced.
On renewal of your contract you can phone and as part of your renewal you can request a new router which should then be free. Renewals can be negotiated within 4 months of you existing contract ending.
Divsec
Message 8 of 9
Hi @Mazzie52 how long does your existing contract have to run?
