Adding recorder
Erik66
Visitor
Message 2 of 2
Is there any way to use my own recorder? Do I need to use different cables or usb? Thanks
1 REPLY 1
Message 1 of 2
No reasons you shouldn't be able to at all. Just use suitable cables to connect to TV and router as appropriate and off you go.
