Apps..my5
Janice66
Message 3 of 3
How do I get a PIN number to access the My5 app
Message 1 of 3
Hi Janice,
How are you getting on?
Message 2 of 3
Have you set up an account on the My5 website? You will need one.
Once set up, open the My5 app on your box, sign in and you should get a code to input on the website.Enter
Enter this code and your account should sync.
