Failed to record
Rusty_2
Message 8 of 8
Our View box has started to miss recording some programmes -what can we do?
Rusty2
7 REPLIES 7
Message 1 of 8
@Rusty_2 that's great. Thanks for confirming.
Rusty_2
Message 2 of 8
Hi fr8ys
I did move the aerial & retuned and then back to the box & retuned
Thanks everything seems to be sorted (I hope)
Thanks again
Rusty_2
Rusty2
Rusty_2
Message 3 of 8
Hi Janatari
Sorry for the late reply.
I seem to have sorted it now or maybe it's sorted itself !
Thanks for your reply
Rusty_2
Rusty2
Janatarl
Message 4 of 8
I presume its the Huawei box ?  Mine did the same I tried every suggestion made, and in the end was offered a replacement set up.
Message 5 of 8
Have you taken the aerial out and plugged directly into the tv and retuned that?
If the TV loses channels it may well be either atmospherics or your aerial is failing in which case you would need to consult a local intaller.
Try tuning the TV first to see what result you get.
The full reset is a last option but for lost channels may be a bit drastic at this stage.
The other thing you can try is to do a retune with no aerial inserted which will produce 0 channels, but clear the box memory. Then reinsert the aerial and try again.
The weather is playing havoc with the signals at present so hold off on the reset for a few days.
Rusty_2
Message 6 of 8
Hi fr8ys,
Thanks I haven't done the maintenance reset yet but decided to retune channels as I know some were being added & some taken off. I went from 175 channels down to 114,  I know one which has disappeared is 38 which I've been using to try & catch the Channel 5 which have been missed on recording but of course I can't do this now. So now I have yet another problem, do you think the reset may solve  both problems I have?
Rusty_2
Rusty2
Message 7 of 8
Which channels are these? There is a problem reported that may be affecting C5. If to it would be worth reporting the issue with examples to them via their website.
C4 previously had an issue too.
If it's across all stations then resets might help.
Have you tried a soft reset? To do this hold the power button on the front for around 10 seconds and the box should restart.
If this doesn’t work then have you tried a YouView Maintenance Reset (https://community.talktalk.co.uk/t5/Articles/How-to-find-maintenance-mode/ta-p/1429347)?
If all else fails then try a full factory reset from the settings menu you've just used above. You will lose your recordings but you may be asked to do this before the Support Staff look at other alternatives.
TalkTalk now only supply non-recordable boxes, So it's best to try all alternatives if recording is important to you.
You will need to phone and probably recontract to obtain a new box.
Hope it works and please let us know how you get on.
Anonymous User
