How do i go about ordering a replacement TV remote
Helen541
Message 2 of 2
My TV remote is playing up and fast forward button is not working
How do I go about getting a replacement remote.
I have a Huawei box.
1 REPLY 1
Message 1 of 2
Unfortunately these remotes are no longer available.
If your box is still working, and you have followed the resetting your remote instructions, then I'd suggest searching ebay for a replacement.
TalkTalk now only offer non recordable boxes and you will probably need to recontract to obtain one of these.
If you wish to get a new, non recordable box try phoning 0345 172 0088
Opening Hours can be found here - https://community.talktalk.co.uk/t5/Articles/How-to-contact-TalkTalk-Broadband/ta-p/2230529#
