Huawei DN360T wont connect wirelessly to eero modem.
conwy36
Message 4 of 4
Getting Error code YVM102 .Having  had fibre installed today, there is no spare port on the modem to provide  a wired connection to the huawei box via the mains sockets., because a telephone is connected . Any suggestions please, Is this box too old to have a wireless facility or any work around that could be done. Thanks
3 REPLIES 3
Message 1 of 4
Thanks @fr8ys
conwy36
Message 2 of 4
Many thanks for your helpful reply. Option 1 is my preferred route.  Cheers
Message 3 of 4
The 360T is not WiFi enabled.
You have 2 options.
1 buy an ethernet port extender that will plug into the back of your router and provide additional ports.
2 phone and request a new TV Hub which is WiFi enabled, but you may have to recontract to obtain one.
Try phoning 0345 172 0088
Opening Hours can be found here - https://community.talktalk.co.uk/t5/Articles/How-to-contact-TalkTalk-Broadband/ta-p/2230529#
