Sky Sports+
garyp41
Message 4 of 4
I have an old Youview box which means I cannot use ITVX, but I am happy to wait for that until I need to replace my TV which is not a smart TV. I am though thinking of subscribing to NOWTV for Sky Sports. I know I can do this but can anybody help with regards to the new Sky Sports + channel which is the one I want to use as it will allow me to watch my team regularly. I do not know if the Youview box I have will have the same constraint as I have with ITVX?
Also would I need TalkTalk TV to subscribe to NOW TV?
3 REPLIES 3
Message 1 of 4
Thanks for your help @fr8ys
Message 2 of 4
Thank you very much, I will start by looking at Now TV website
Message 3 of 4
The Now website gives you a list of compatible devices.
It may also be worth looking at the now website for deals direct and compare the 2. The TalkTalk offer does come with the HD boost though. Not sure if you need the TV boost with TalkTalk though.
Have you considered an Amazon Fire Stick which would give you both ITVX and Now with no issues, assuming you have a spare HDMI port on your TV.
Just a thought as this is a one off cost rather than the TalkTalk Hub on a monthly basis.
If you need the TV charge to access the Now offer the Hub does have the latest apps and you can use this alongside your existing YouView box as the hub does not record.
Hope this helps.
