NOW Sports Package but no Boost
peterfenton
Sightseer
Message 11 of 11
I began a new subscription to the NOW Sports package yesterday. However, the boost function is not working so I can only watch on one device and it is not in HD or with Dolby 5.1
Is it possible for this to be fixed?
10 REPLIES 10
Message 1 of 11
Hi Peter
Glad this as now been fixed for you.
peterfenton
Sightseer
Message 2 of 11
Hi Karl,
I've just got home from work and the boost is now working.
Thank you very much for all the help.
Peter
Message 3 of 11
Hi @peterfenton
One of our Team have reached out to me directly requesting I pass your account details across to get this processed manually.
Message 4 of 11
Our Team are currently working through these to add the Boost manually.  They have not given a Timescale but I do have positive reports of this working.
peterfenton
Sightseer
Message 5 of 11
Hi Karl,
I cancelled the paid for upgrade to Boost so just used the 7 day free trial, which worked well. The trial expired yesterday and Boost is no longer working. It has reverted to SD, stereo sound only and for use on only one device at a time. So it looks as though I'm going to have to pay £6 per month to get Boost to work.
Thanks,
Peter
Message 6 of 11
You can cancel the boost you have via NOW TV, and test to see if your channels continue without Ad's and on other devices.
Message 7 of 11
Well along with giving you HD, the Boost also allows you to watch simultaneously on up to 3 devices. So you can check that way.
peterfenton
Sightseer
Message 8 of 11
Hi Karl,
thanks for that, however it's difficult to know whether the fix has worked or not because I hae already signed up to boost. The 7 day free trial ends tomorrow and I am due to be billed for £6 per month after this.
Thanks,
Peter.
Message 9 of 11
Hi @peterfenton
Our Teams have applied a manual fix for you, can you test and let me know if the HD Boost is showing for Now TV.
Message 10 of 11
Hi @peterfenton
Our Teams are investigating to see why this as happened.  there is currently no workaround, and I do not have a timescale as yet for resolution.
