on 31-07-2025 06:21 PM - last edited on 31-07-2025 06:32 PM by fr8ys
I received an email containing these codes for Now TV To sign up for CINEMA, use code:
Xxx
To sign up for Entertainment, use code:
Xxx
And to get the NOW HD boost free for 12months, use code:
Xxx
However when I log into my NOW account and choose the associated memberships I am told the codes are not valid!
I have contacted NOW TV but they are not able to offer a solution to the problem.
Any help or advice would be appreciated. Best wishes Dave.
on 01-08-2025 08:40 AM
@Talman please note that you need to contact NOW directly as it is no longer active with us.
on 31-07-2025 07:00 PM
Ok, I'll have to leave this for support staff to look into.
on 31-07-2025 06:50 PM
I have just tried setting up a new account and it still tells me the codes are invalid!🙁
on 31-07-2025 06:43 PM
Thanks for the response! I am signing in with the account I set up via TT, if I try to set up a new account I am told an account is already set up on my email address!🤔🙄
on 31-07-2025 06:31 PM
Has your TalkTalk subscription ended?
Are you signing in with TalkTalk credentials or have you created a new account?
I'm removing the codes in case they are specific to you as you wouldn't want tome9ne else using them.
