on 28-10-2025 06:16 PM
Hi. I have the 4k box. The programme information at the bottom of the screen on a number of the channels does not match the current programme. It displays programme information from 22nd October instead of todays. The now playing programmes on the home screen also show the 22nd October programmes.
I have performed all resets, including mains, router, factory resets and formatted the box. Any advice, please?
Tuesday
Please send your address using private message.
Tuesday
Yes it is . I have also reinstalled everything several times
Tuesday
Please check if the software version is up to date.
Tuesday
Yes it does
Tuesday
Does the Network Connection Status show as Connected?
Tuesday
Yes I have
Monday
Before we continue with the troubleshooting with your TV Issue, we need to have the remote control available and working.
Do you have the remote control of your TalkTalk SetTop Box?
Monday
Okay thank you, please bear with me.
Monday
Yes, I am still experiencing the issue. I have disconnected everything as advised.
Monday
Hi there @Cranver1 are you still experiencing an issue?
Saturday
@Cranver1, staff support is daytime only, Monday to Friday, so there won't be a follow up from them till after the weekend.
Saturday
Hi, I have disconnected everything everything as advised. Still no change.
on 30-10-2025 07:05 AM
Unplug all the external devices by disconnecting any HDMI devices, USB drives, or adapters and observe if the information changes. Thanks
on 29-10-2025 11:39 AM
Yes. All set up. The Now On TV on the home screen also shows programmes from the 22nd October
on 29-10-2025 07:47 AM
Just to confirm you have a TalkTalk TV 4K Box and currently using it within the setup?
on 29-10-2025 07:40 AM
Okay, thank you. Please bear with me, I will get back to you once I have an update.
on 29-10-2025 07:37 AM
The channel number matches the programme. When you initially select/change the channel, the programme information briefly displays at the bottom of the screen. It is this info that does not match the current programme and date.
on 29-10-2025 07:02 AM
@Cranver1 just to confirm everything works fine besides the fact that the number of the program is displaying a different program?
on 28-10-2025 06:52 PM
Yes all connected. Catch up works fine.
on 28-10-2025 06:27 PM
Have you checked that it is connected to the internet OK?
