on 22-09-2025 06:40 PM
My talk talk box is broken. My smart tv is connected to my Wi-Fi and I can access BBC iPlayer, Four, Five, and Netflix but I cannot access/store free view channels. The tv is now plugged into my estate’s communal aerial instead of the box but should the other end go into the back of the tv now that it is out of the tv box? Daft question, and can’t get through to the Technical Team. Thank you.
on 26-09-2025 08:33 AM
@Liddlek, you'll need to follow up on your own thread, which is here:
https://community.talktalk.co.uk/t5/TV/No-channels/td-p/3132043
If you lose track, check in your community profile area under ACTIVITY. You can find your way back to your own topic and it's replies there.
on 26-09-2025 08:24 AM
Thanks, it'll try this later (& check a spare tv also on same aerial with freeview in a room not used for a while). Thanks again.
on 22-09-2025 06:45 PM
Which box do you have? Do you need help with this?
on 22-09-2025 06:44 PM
The TV aerial needs to be plugged directly into the TV, bypassing the box, i.e the plug that went into the box should go into the TV
Hope this helps.
