TV Guide not working
Mmatt
Message 41 of 41
The TV Guide isnt working properly. You can't change channel with it. It's very slow to appear. After about 2 hours it springs back to life and seems to work properly. But if you turn the TV off it goes back to being slow or freezing. I've re-booted the box twice, turned the TV connection off and on. Changed remote batteries. All made no difference.
40 REPLIES 40
