Tv remote not working
DanLee279
Sightseer
Message 15 of 15
Hi there,
Recently my remote would no longer connect via Bluetooth and now it won’t even turn the box on. How do I resolve these issues? I have already tried turning it off and on again, new batteries and a factory reset with no luck.
Dan
14 REPLIES 14
Message 1 of 15
Great, just to check, are you only having issues when trying to connect via Bluetooth/turning the tv box on using the remote or there's other issues as well?
-Fez.
Message 2 of 15
Okay
Message 3 of 15
Thank you, I will need to look into this for you and may include a few checks which will help us understand the cause of the issue and a possible resolution to it, will that be fine with you?
-Fez.
Message 4 of 15
Yep no problems with the broadband
Message 5 of 15
Thank you so much, are you currently able to use your broadband services without any issues?
Fez.
Message 6 of 15
Yes
Message 7 of 15
I am so sorry to hear about that @DanLee279 , are you currently home where the services are installed?
-Fez
Message 8 of 15
Hi Fez,
I have attempted the above actions as directed apart from trying an alternative Bluetooth device as I don’t have another. I am still unable to use the remote or pair it via Bluetooth. Can you organise a replacement?
thanks
nomfezeko-TT
Message 9 of 15
Hello @DanLee279 , thank you for reaching out to us. I’m sorry to hear that you’re experiencing issues with your remote. Since you've already tried turning it off and on, replacing the batteries, and performing a factory reset, let’s explore a few more troubleshooting steps:
-Please ensure that there are no other electronic devices nearby that might be causing interference with the Bluetooth connection. Sometimes, devices like microwaves or wireless routers can disrupt the signal.
- If your remote is Bluetooth-enabled, try to re-pair it with your box. To do this, hold down the pairing button on the remote (usually found in the battery compartment) until the LED light starts flashing. Then, follow the on-screen instructions on your TV to complete the pairing process.
- Check for any physical damage to the remote. If any buttons are stuck or if there’s visible damage, that could be affecting its functionality.
- If possible, try using the remote with a different compatible device to see if it works there. This can help determine if the issue is with the remote or the box itself.
 If none of these steps resolve the issue, please do let us know so we can further assist.
-Fez.
Message 10 of 15
I have updated my info, thanks
Message 11 of 15
I hear your concerns and thank you for feedback on this.
Before continuing any further, please update your community profile and add your landline number and/or account number so your account can be identified. Please don't post personal information here.
https://community.talktalk.co.uk/t5/user/myprofilepage/tab/personal-profile:personal-info
Message 12 of 15
I am still having issues with it and now the hub box won’t even allow me to cast to it. Please can you organise a replacement for both?
thanks
sabelo-TT
Message 13 of 15
@DanLee279, a very good morning to you.
Just checking if you are still having any issues with your remote control. Kindly confirm with feedback once you have received this. 🙂
Message 14 of 15
Whilst you've done a factory reset of the box, have you tried a remote control reset?
Details can be found here
https://community.talktalk.co.uk/t5/Articles/TalkTalk-Remote-Control-Guide/ta-p/2204370
See if the remote works on IR, then try reconnecting via BT.
When in infra red mode, if you have a smart phone, use the camera and point the remote at it, the press a button and you should see it light up. If not the the remote is dead. Note this trick does not work on Bluetooth connected remotes.
TalkTalk don't replace just the remotes so you would need a replacement box in that case.
Let us know how you get on.
