Why does the tv box affect the aerial signal strength?
Sxg30
Newbie
Message 2 of 2
TV box
1 REPLY 1
Message 1 of 2
Which box do you have?
What device is showing a low signal strength and what symptoms are you experiencing?
Do you have a separate feed to each device?
If not how are your devices linked up and which device is first in the link?
Have you tried linking in a different order?
