my new 4k talktalk tv Remote volume indicator does not appear on the screen
Roxbah
Message 2 of 2
my new 4k Talktalk TV remote volume indicator does not appear on the TV screen
1 REPLY 1
Message 1 of 2
Which box do you have, the TV Hub or the 4k Netgem Box?
Have you tried a reset of the box? This will download the box software again and if it's a bug will hopefully solve this.
