on 19-11-2025 12:04 PM
how do I fix it
on 24-11-2025 07:05 AM
@Touchstone* I can see that @ferguson had asked if the box can connect, I take as that it could connect as you were advised that you should not worry about the light as long as the box can connect.
on 19-11-2025 12:06 PM
Is the TV box connecting OK? If so, don't worry about the router light.
