on 16-05-2024 10:41 PM
Twice this evening my router has lost the connection , flashing yellow light, and then it has restored itself. I have also been losing the 2.4ghz channel repeatedly over the last week.
yesterday
I disagree as I fail to see how uniting them will let me see which band is failing. It is repeatedly the 5ghz band that my ipad fails to connect to and the ipad says that this because of too many other routers in the vicinity operating on the same channel.
Wednesday
Hi CMJTW
I think it's best we monitor the connection without the SSID's being split. Will this be ok? I can check the wireless stats again.
Wednesday
Yes they did.You can see further up this topic
Wednesday
Hi CMJTW
Did they make changes whilst the SSID's were split?
Wednesday
One of your colleagues had previously made some changes to optimise the signals
Wednesday
Hi CMJTW
Would it be possible to factory reset the router back to default settings so WIFI optimisation can pick the best channel for your line. Just so we can see how the connection compares?
Wednesday
Yes I have so I can see which channel isn’t performing well.
Wednesday
Hi CMJTW
Ok, have you split the SSID's on your router?
Wednesday
This is a new router you sent only a few weeks ago.
Wednesday
Hi CMJTW
We do suggest rebooting the router at least once a month.
If you're having to reboot the router more often than that, then we can send a replacement router just in case the one you received was faulty.
Wednesday
The 5ghz recovered after I rebooted the router but this morning it is suffering again when I connect to it. When I try and open a website the browser never connects due to buffering. I have swapped back to the lower band which is working well.
Monday
Good morning,
I'm sorry to hear this. How has the connection been since you rebooted the router?
Sunday
Rebooted the router and it has returned , but why does this happen?
Sunday
This afternoon I have lost the 5ghz channel and none of my devices can discover or connect to it
on 29-05-2024 06:39 AM
I'm glad to hear this and please let us know if anything does change or you need any further assistance 🙂
on 28-05-2024 05:28 PM
The internet seems to be a lot more stable than previously.
on 28-05-2024 06:39 AM
Good morning,
Just checking back in to see how you're getting on?
on 23-05-2024 12:10 PM
No problem, we'll check back in with you on Monday 🙂
on 23-05-2024 11:43 AM
Let me monitor it over a few day and I will report back on Monday.
on 22-05-2024 03:11 PM
I can see you have separated the Wi-Fi bands so that rules out any sort of band switching causing the drops. I've made a channel change to the 2.4Ghz based on current traffic and reduced the operating bandwidth of 5ghz to see if this shows improvement with stability across the 2 Wi-Fi bands to your devices. See if there is any marginal improvement this evening, and if not we will look at another option to improve coverage for you.
