Slow output
TCAR5
Message 9 of 9
Good evening,
We have a Sagemcom 5364 router and have an issue with it, it is showing 17.2 download and 1.2 upload from within the router itself. (192.168.1.1)
I have only max 3.9 output both on the Ethernet and the Wifi.
I have tested this with the Wifi totally off and only a laptop connected via Ethernet cable and using Speedtest.
This has been reported and an engineer has been booked for the 5th Dec however I was wondering if this issue has been reported before and a fix is known.
Various tests were done and factory reset done with no fix. I have a friend who is a network engineer and he looked and thinks it's a faulty router. Can a new one be sent to try and potentially save an engineer visit?
8 REPLIES 8
Message 1 of 9
Hi TCAR5
I'm just sending you a Private Message to confirm some details so we can cancel the engineer visit.
Message 2 of 9
Michelle/Karl. The new router arrived yesterday and with all devices connected (smart home bulbs etc) it's showing just under 14Mbps and 1.2. This is what it should be, for whatever reason the old router is busted! Thanks again for your help.
Please cancel the engineer visit booked for the 5th.
We are in the countryside and approx 3/4 of a mile from the "green box" with an estate between us. The line runs up the lane from the box and we are the last house. The internet has always been poor here and working from home has been a nightmare. The line is always intermittant and dropping.
About 300 meters from us further up the lane, there is a farm and the owner paid for a full fibre line, I'm not sute if this is FTTP or EAD, but the lines have junction boxes running down each pole (one not 4 meters from me now). The line runs past our window teasing us.
This is so frustrating as OPENREACH won't confirm if this was fitted privately or not.
Is there anyway of checking the viability of access to this line with OPENREACH, trust me there are plenty of people up this lane that would benefit from it.
Thanks again
Message 3 of 9
Great thank you. We'll check in next week.
Message 4 of 9
I will Michelle, not received it yet but will let you know.
Message 5 of 9
Please let us know how the connection compares 🙂
Message 6 of 9
Thanks Karl, fabulous I appreciate your help.
Message 7 of 9
A router is on the way to you to see if this helps.
Skynet_TX
Message 8 of 9
Hi @TCAR5,
Have you tried leaving the router switched off for over 30 minutes, this will ensure you get a brand new session in the street cabinet when you switch it back on, this can sometimes resolve issues where the throughput speed is significantly less than the sync speed reported in the router.
The TalkTalk Support Team on this community will also be able to help, they will hopefully be able to respond to this post tomorrow.
