5ghz dropping and can't reconnect
Grovesy1988
Message 12 of 12
Hi folks,
I'm here as a last resort having gone through talktalk webchat 4 times over the last few months. I'd be grateful for any advice.
As the title suggests, my 5ghz connection keeps dropping. When it drops I am unable to reconnect until a router restart. The 5ghz will be visible but it either won't recognise password or dhcp error. Once restarted, all is well. This is not exclusive to one device. The 5ghz network will be visible but can't connect on any device.
So far I've tried the following;
Reset router
Same SSID
Splitting the network
Every channel available
Powerline adapters
Range extenders
Firmware upgrade via tech support
Changed all cables
Relocated router
Disconnected devices periodically to rule out interference
I'm at my wits end. The 2.4ghz connection is OK but I get an awful amount of latency spikes. When connected, the 5ghz gives me the full 150mbps, 100% signal strength and incredible low latency.
Many thanks.
11 REPLIES 11
Message 1 of 12
Hi Grovesy1988
That's great news, thanks for letting us know 🙂
I have sent you a Private Message with a link to a short survey for the Community.
Thanks again.
Grovesy1988
Message 2 of 12
Just wanted to say thank you to both of you for all your help. I'll continue monitoring but it seems that everything is now resolved. The replacement router hasn't disconnected once and the firmware upgrade took my signal strength from 58% to 100%.
Best wishes
Message 3 of 12
Hi Grovesy1988
I've updated your router firmware to the latest version.
Message 4 of 12
Hi Debbie,
It's version SG4K100136.
Many thanks.
Message 5 of 12
Hi Grovesy1988
Thanks for your reply. Which firmware version is showing on the router?
Grovesy1988
Message 6 of 12
Afternoon,
Received the replacement router and we're all up and running. Connected with no issues and so far no drops.
Having tested the connection I think the wifi extender model number F@ST266 is having no impact on signal strength. I've reset the extender and repaired with the router. It seems to be connected but not actually doing anything. Will the new router require a firmware upgrade to be fully compatible with F@ST266?
Many thanks.
Message 7 of 12
You're Welcome 🙂
Message 8 of 12
Appreciate it, thank you.
Message 9 of 12
A router is now on the way to you.
Message 10 of 12
Hi Karl,
I've just updated my profile with the landline telephone number.
Many thanks
Message 11 of 12
Can you add your account number or home phone number to your 'Community Profile' and I can locate your account and send a replacement router to you, to see if this resolves the issue.
