2.4Ghs
Jcpiso
Message 2 of 2
How do I check in what connection I’m on. 2.4 or 5 Ghs. Want to connect a smart plug it says the connection needs to be on 2.4
1 REPLY 1
Message 1 of 2
The 2.4Ghz and 5Ghz wifi will have the same name and password.  If the plug is only capable of 2.4Ghz then it should only connect to 2.4Ghz. band.
Some older devices may have an issue with the wifi networks using the same name (SSID), so if you have any issues you can log into the router and change the name of one of them, for example you could just put 5G at the end of the 5Ghz wifi name so you can then tell them apart.
Anonymous User
