Broadband Connection
StevenCH
Message 5 of 5
All of my devices normally have good internet connection, but when I connect my pc to the internet I lose connection on my other devices.
4 REPLIES 4
sabelo-TT
Message 1 of 5
Hello there @StevenCH, just checking to see if you are still experiencing connection issues. Kindly confirm with feedback once you have received this message.
Message 2 of 5
Hi @StevenCH
Thanks for the ipconfig output; everything looks fine. From the symptoms of slow connections, etc, this may be more of a WiFi interference problem.
In other words, I offer a free, impartial analysis of your Wi-Fi network and will try to help you optimise your Wi-Fi connection. The next stage involves sending out a guide to help you get me some important diagnostic results so that I can analyse them for you and recommend changes to your router configuration to solve them.
Message 3 of 5
Thanks for your PM, just to clarify for the rest of the forum, the answers to my questions were:-
1 The make/model of the router: Sagemcom Fast5364-T8 runningSG4K100208 firmware.  I believe the timing of this issue may coincide with this firmware release.
2 Devices are all connected wirelessly.
3 WiFi
4 No.
I have seen a couple of threads about WiFi issues with firmware V208, but I have never been able to replicate this myself.
Your case is different anyway, because it is only when your PC connects to the Wi-Fi that you have the problem. I feel the most likely causes of your problem are:-
  1. An IP address conflict between your PC & other devices or the router.
  2. Your WiFi adapter in your PC is faulty (less likely).
When you connect your PC (assuming it is running Windows), please go to the command prompt and issue the command:-
ipconfig /all
Please PM me (to protect your privacy) the output from this command.
The information below is provided by TalkTalk. For confirmation, please contact @Lorrainef.
If you need further help or if we need to take any details such as personal information about your account like phone numbers, account numbers, etc, one of the TalkTalk team will jump in and help out.
Message 4 of 5
2. How are your device connected to the router, via wireless, wired (Ethernet) or a mixture?
3. How does your PC particularly connect to the router?
4. Have you made any configuration changes to the router particularly around IP addresses or DHCP?
