Broadband connection
James_79
Message 3 of 3
Hi, I'm constantly having to turn my router off and on again, this is even after changing settings as directed by talktalk's website via the router login, I think it was the channel.
I'm still getting slow speeds unless i turn it off then on then it goes back up for a day or so then I have to do it again.
There's nothing in the routers way, it's close enough to where I need it and it's plugged direct into the wall rather than an extension socket so I'm now at a loss but can't find a way to send a message to talktalk to find a way to sort it out, thanks.
Jamz
Chris-TalkTalk
Message 1 of 3
Hi James_79,
  • Name
  • Telephone number
  • Alternative contact number
Skynet_TX
Message 2 of 3
Hi @James_79
What model of router do you have ?
Do you have devices connected both 'wired' and 'wireless', if so do they all suffer the same problem ?
