Wireless connections
windpower
Message 4 of 4
When connecting  devices (mobiles or tv) to the wireless, the Mac Filter mode as to be set  to Allow all for the connections to succeed. However when Mac Filter mode is set to Allow devices can not connect. Note that I have added the devices mac address before changing Mac Filter Mode.
Any help?
3 REPLIES 3
Message 1 of 4
Usually you just set the devices to recognise the router and add the router password that comes with the router, @windpower
We don't usually play with any settings unless you are wanting to change the wifi password etc to make it more secure.
windpower
Message 2 of 4
Hi Divsec
My router is Fast5464 2.00
Divsec
Message 3 of 4
Hi @windpower it would really help if you could tell us which router you have. I've never had to touch mac filter settings on my sagemcom hub.
From the 29th of March our TalkTalk Community will move to peer-to-peer support and the TalkTalk team will no longer be here to support with queries. Don't worry we still have plenty of ways to reach out if you need to speak to TalkTalk directly. For more details check out the link here: How to contact TalkTalk Broadband - Help & Support.
