on 18-06-2022 10:03 AM
On Fibre 65, speed is usually about 70mbp, the last week it has been between 7 and 20 today. Have gone through all the suggested fixes and nothing is making it any better
on 19-06-2022 09:58 AM
Router is a DG8041W, logging onto the router it says speed of 68.96. Just done more speed tests today wired and wireless, highest speeds I am getting is 33.2
on 18-06-2022 10:23 AM
2. If you log into the router, what speed is it showing there? If it is one of the WiFi Hubs, this is in the initial dashboard area.
3. If you have any wired connections, are they affected in the same way as wireless ones?
