Wednesday
My broadband was working fine up until 9.15am this morning, but then stopped.
I have rebooted the router several times now, leaving for over 20 mins in between.
It has been flashing from orange to white.
Please help!
Wednesday
Once the systems are back up, your thread will be prioritized.
Wednesday
Ok, please let me know as soon as you have any updates.
Thank you
Wednesday
Our systems are still down at the moment, which is preventing us from running the necessary diagnostic checks on your line. The estimated time for the systems to be fully operational is within the next 2–3 hours.
Wednesday
I understand, I will check for you.
Wednesday
Hi, I'm just wondering if you are able to run the tests you need to do now, to see what the issue is with my connection?
I'm mindful that if it is the router, there might be a delay in getting a replacement to me in good time.
Can you give me an update please?
Thanks very much
Wednesday
We really appreciate your understanding and patience.
Wednesday
@ChristoffBas At the moment, we’re experiencing a system issue that’s preventing us from running the usual diagnostic checks on your service. Because of this, we’re unable to confirm whether the problem is with the router or the broadband signal right now.
Wednesday
Thank you. After trying everything so far - would you say it's either a router issue or with the actual broadband signal not getting to the router?
I will wait to hear from you. Currently connecting via my phone's hotspot.
Wednesday
Thank you so much for trying @ChristoffBas once our systems are up and running, we will be able to pick up your thread and do checks on your line. We once again apologize for the inconvenience.
Wednesday
OK, thanks for trying.
Wednesday
I've just plugged the router directly into the main BT box - it's exactly the same problem. It's not getting a broadband signal.
Wednesday
Off cause.
Wednesday
May I just ask whether you have tried connecting the router directly at the test socket using a plugin microfilter?
Wednesday
Ok, can you please keep me updated.
Thank you.
Wednesday - last edited Wednesday
I'm really sorry about that, more checks need to be carried out however we are currently experiencing system issues making it difficult to proceed with the checks. The outage we are having should probably be over in 1-2 hours' time and we can continue afterwards. I'm sorry about the inconvenience that this must be causing you, I do understand how frustrating this must be on you.
Wednesday
I reset the router (holding in pin for 30 seconds until orange light went out). It then went through a reboot - with orange and white light flashing. It has now gone to a constant orange light again.
Wednesday
Please confirm once that's completed.
Wednesday
Please reset your router via the 'Reset' pin hole on the back. To do this you'll need a pin, straightened paper clip or other tool that fits in the hole, which you'll need to hold in for 30 seconds.
Wednesday
Thank you for confirming, a factory reset is required on your router which will restore the router to it's original settings, including the Wi-Fi Network name (SSID) and password.
If the password has been changed, please refer to the one on the stickers attached to your router to find the original password.
Once the No Internet connection issue is resolved, I can assist you in reconnecting to the network
Wednesday
No
