COMMUNICATION ERROR WITH THE GATEWAY
agustusin
Message 2 of 2
I've just tried accessing the admin pages on my router to find it is giving a:
"Communication error with the gateway" error.
I've tried rebooting the router - no change in behavior. I'm also sure I'm using the correct credentials.
The system seemed to fine before so this seems to be new. Any suggestions? A bug in the new firmware? Or a failing piece of hardware...?
1 REPLY 1
Message 1 of 2
Hi agustusin
Have you also tried factory resetting the router using the pin hole reset for ten seconds?
