Cant connect to new equipment
Janethom
Message 4 of 4
Can't connect to new equipment
3 REPLIES 3
Message 1 of 4
Hi there @Janethom please answer the above questions so that we can assist you further. Thanks
@KeithFrench and @fr8ys thanks for helping out.
Message 2 of 4
Could you please expand upon your issue and what equipment won't connect to what, so we can offer advice.
Also, you are in the staff's queue for a response.
For a quicker reply can you please ensure you have your personal information up to date in your profile including your TalkTalk landline phone number so your account can be traced. Link here - https://community.talktalk.co.uk/t5/user/myprofilepage/tab/personal-profile:personal-info
You can also add your account number in the private notes field, which only you and the support staff can view.
Please post back when done.
Thank you
Message 3 of 4
Please can you elaborate on this? Is this existing devices that connected OK to an older router & not to some newer one, or is it something different?
I will need to know the make/model of the router that you have and if my former guess is correct, how are these connecting to the router? Is it via wireless or a wired (Ethernet) connection and what error message do you get when trying to connect them? It would help to know the type of device that cannot connect.
