Change Wifi Channels - Options disappeared
Alex-S
Message 4 of 4
Router version: SG4K100174
Looking to change my route channels as the channels currently in use are always very very crowded where I live.
Where has the option gone?
3 REPLIES 3
Message 1 of 4
Hi Alex-S
Login to the router & go to:-
Dashboard > See Wi-Fi Settings > Manage Advanced Settings > Wi-Fi 2.4Ghz gear icon > Basic
The repeat for the 5GHz band.
However, never change channels without first using a WiFi Analyser.
WiFi Optimisation has total control over the WiFi settings, it has had this for several years now.
Message 2 of 4
Might not have moved in this build but I can't find it anywhere. Read something about WiFi optimisation. Any thoughts?
Message 3 of 4
It hasn't gone anywhere in 174, where are you looking?
