Chime keeps dropping off broadband - firmware?
Hethers
Message 18 of 18
my chime (Ring) keeps dropping off the talktalk Wi-Fi and I’ve read this is possibly a firmware problem.
Can I get this updated please? I’m currently on SG4K100158 I think.
Many thanks!
hethers
17 REPLIES 17
Message 2 of 18
Hi @Hethers
I will PM you a link for a guide of mine on Wi-Fi interference & initially look at the section called "Are you suffering from interference – prove it first". This section includes full details of Wi-Fi analysers that I recommend for Windows, Windows phone, Android and Apple operating systems. However, I have no way of testing the Apple product. Do not worry about interpreting the results, I will do that for you.
Please post the screenshots to me in a PM (to protect your privacy), which I have requested in my guide. No photos please they can be difficult to read as text can get out of focus when zoomed in, from the analyser you are using (also in my attached guide). Please ensure that the analyser window is maximised (if Windows) before taking the screenshots & upload them via the "Insert Photos" button (in a mobile browser it's the picture icon) on the post editor's toolbar with the Size parameter set to Large. If they are too small, I will not be able to read them & although I can enlarge them, this puts the text out of focus.
Message 3 of 18
Hi Hethers
I've switched the optimisation off.
Thanks for your help @KeithFrench
Message 4 of 18
Hi Keith
Yes please. I have requested they disable the optimisation.
regards
Hethers
Message 5 of 18
Hi @Hethers
I can still help to find the cause, but the resolution may be reverted until WiFi Optimisation disabled.
If you want to try this, let me know.
Message 6 of 18
No - like I said it was fine for years there until recently when it started dropping off the Wi-Fi. I’ve moved it since to try to improve it but it isn’t helping.
Message 7 of 18
So did the issue start when there was 3 meters between the chime and the router?
Message 8 of 18
I have thanks - it has also been in the room next door approx 3 metres away. It was there and working for 2-3 years before this recently became an issue a couple of months ago, and now it won't stay connected for more than a couple of hours.
Message 9 of 18
Could you move them further apart and monitor to see if this makes any difference
Message 10 of 18
Approximately 12 inches.
Message 11 of 18
Hi Hethers,
Approximately how far away is the chime from the router? Is it in a different room?
Message 12 of 18
Hi Debbie
As per @KeithFrench suggestion above, can you disable the wifi optimisation please? The router firmware upgrade has made no difference to the Chime dropping the connection to the 2.4GHz band.
Hethers
Message 13 of 18
Thanks, I've just checked and your router now has the latest firmware version - SG4K100174
Message 14 of 18
Hi Debbie
I have done that
Hethers
Hethers
Message 15 of 18
Hi Debbie
I have done that
Hethers
Message 16 of 18
V174 is the latest firmware, but I doubt if this will have any impact on your problem at all. The Ring only works on the older 2.4GHz WiFi band, which is very susceptible to WiFi interference.
Have you had TalkTalk’s Wi-Fi optimisation disabled on your Sagemcom FAST5364/5464 router? When this is enabled, as it is by default, it has the power to override any Wi-Fi configuration changes that I might suggest that you need to make. This will not help rectify this type of problem if Wi-Fi Optimisation is allowed to change my suggested settings. Only TalkTalk can do this for you, you cannot do it yourself. If not, just request they disable this for you in your reply.
Message 17 of 18
Hi Hethers
Thanks for creating a post on the Community.
Please can you add your name and TalkTalk landline number to your Community Profile, I can then take a look at this for you.
