setting upwifi extenders
grumpygranny
Message 3 of 3
i need these in every room, they arent all the same make but mostly BT ones, one is a hwawei. theres some conflict and it makes the broadband speed drop from an average of 48 down to 12
Chris-TalkTalk
Message 1 of 3
Hi grumpygranny,
How are you getting on, do you still need assistance
Message 2 of 3
Hi @grumpygranny
You should not need them in every room, there is every chance that by doing this, you will make the signal & hence the speeds much worse. What you need to do, is to investigate what the problem is & only put extenders (if required) in one or two places, unless you have a very large property. I can help a lot with this investigation.
Slow speed, intermittent dropouts, breaks in the signal, no signal on some or all devices or no internet access might be caused by Wi-Fi interference from other local networks, which can also lead to a permanent reduction in speed. No ISP can be responsible for your local environment, this is mainly a byproduct of the popularity of Wi-Fi.
In other words, I try to help you optimise your Wi-Fi connection. If you would like me to help you, please can you specify the make/model of TalkTalk router that you are using?
