on 04-09-2024 08:54 AM
Having frustrating issues with my talktalk router not being able to connect with my Blink Sync Mod2. The module, which controls my security cameras, works on 2.4 GHz freq. Whenever I try to pair the router and SM I get the incorrect password error. (I know it’s correct)
ironically, if I plug in a tp link WiFi extender the SM will connect. However, it’s hit & miss and is unreliable.
I’ve tried powering off the router, Sync Mod, resetting, persistence with trying to connect all without success.
My system has previously worked so I’m at a loss why I can’t connect with the router.
Help !!!
Thursday
I'm glad to hear this and thanks for confirming 🙂
Wednesday
That's great to hear, thanks for letting us know. 🙂
Wednesday
Finally,,,, issue resolved.
i sent for another Blink Sync Module and after a call to Blink Customer Service, the firmware on the module was updated and Hey Presto ! I can now get connection between the Module and router and get motion video
on the USB flash drive.
on 06-09-2024 11:31 AM
Yes that’s right…I think the router is working fine. Other devices connect to it, no problem.
andy
on 06-09-2024 11:13 AM
I thought that you had the router replaced a while back as well?
on 06-09-2024 11:12 AM
Sure, I understand what you’re saying, however I can connect the extender to the sync mod using either iPhone or iPad.
i think the common denominator in all this is the sync mod itself.
Despite numerous resets and power cycles it just doesn’t want to cooperate.
I’ve invested too much time and effort just to give up. So, contemplating buying a new Sync Module and trying that.
im stuck re any other possible solutions.
thanks for all your help
andy
on 06-09-2024 10:44 AM
Yes, I think that they run the same Apple software as iPhones.
on 06-09-2024 10:42 AM
ive tried connecting with iPad too results in the same issue.
thanks again
andy
on 06-09-2024 09:45 AM
There is a bug with iPhones that prevents you from accessing the UI.
on 06-09-2024 08:48 AM
Ah ok. So the blink device connects ok, it's just certain features that don't work? Apologies for all the questions, I've not come across this device before.
on 06-09-2024 08:46 AM
The problem began a few weeks ago so Talktalk sent me a new router …
So, no I was getting the issue with the old Sagencom router too.
on 06-09-2024 08:38 AM
Hi Andy,
Can I just confirm, has this previously worked ok with this router and has only just stopped working?
on 06-09-2024 08:36 AM
Hi Michelle
Situation is the same. Can’t get router to connect to Sync Module. The router appears as an option to connect to, but alas no joy.
on 06-09-2024 08:12 AM
Hi Andy,
The firmware has now been updated. Please let us know how your connection compares.
on 06-09-2024 08:02 AM
Yes Please…. could you let me know when the update is finished and any instructions you would like me to try.
Andy
on 06-09-2024 07:52 AM
Hi andyb101
We have new firmware available for your router.
Will it be ok for me to update your router to the new version this morning?
We advise to leave the router switched on without being rebooted whilst we update the FW. It should take no longer than 15 minutes to update.
on 06-09-2024 07:31 AM
Morning Michelle
thanks for getting back.
Still can’t connect router to Sync Module….done resets on both router & SM. I’ve plugged in extender and the system is on… however, only getting limited functionality with my cameras. The signal strength not great.
this is the only way I can get any use from the cameras.
on 06-09-2024 07:22 AM
Morning andy,
Thanks for the update. How are you getting on?
on 05-09-2024 05:58 PM
ive plugged in an extender and connected my Blink sync mod to it. All’s good. Blink system up & running.
will check a few things as it just updated firmware ( which may make a difference and allow me to connect router to module.
on 05-09-2024 05:47 PM
It could conceivably be a faulty router. Before reaching that conclusion though it may be worth one more try. Reset the Hub with a pinhole reset so it returns to factory settings. Reset the module again. If it still doesn't connect, see if you can get into the router settings to change the SSIDs. If you still cannot access the router settings, wait for a further response from the support team when they are back online tomorrow.
