DHCP reservation issues
mikegostev
Message 7 of 7
I have issues with DHCP reservation. Whenever I add the new reservation the router rejects it because some my existing reservations "already in use". It looks like a UI/FW bug. Any ideas?
6 REPLIES 6
Message 1 of 7
What happens if you reserve the IP address the device already has, via the device listed in the initial Advanced mode section? I can't say I have noticed any problems, but a screenshot of what you are trying to do would make it easier for me to see if I can replicate your problem.
mikegostev
Message 2 of 7
Serial NumberHardware VersionSoftware VersionGUI Version
N7191784N002270
FAST5364 3.00
SG4K100136
5.6.1
I don't reuse IP. I add the new reservation, but the UI shows a error on one of the previously existing reservations. It says "IP already in use". Of course it is but I don't change it I just add something new.
Message 3 of 7
Hi @mikegostev @Debbie-TalkTalk
What firmware is your Sagemcom running, you have only quoted the hardware revision?
To reuse a previously reserved IP address, the device that used that address previously must not have tried to connect to the router for more than 24 hours (default DHCP Lease time is 1 day). Once this timer has expired, the IP address should be available again. If you do not want to wait that long, reboot the router.
Message 4 of 7
Hi mikegostev
Thank you.
@KeithFrench is this an issue you have reported?
Message 5 of 7
Hi.
It is Sagemcom FAST 5364-3.T8
Message 6 of 7
Which router are you using? (make and model)
