Eero
Deepways6
Message 4 of 4
I had eero installed yesterday and having problems with a couple of devices connecting too it. It said connection is poor. I’m really disappointed as was promised a better connection and it is definitely worse
3 REPLIES 3
Chris-TalkTalk
Message 1 of 4
Hi Deepways6,
How are you getting on, has Keith and Gondolas's advices helped?
Gondola
Message 2 of 4
Hi Deepways6
The eero app has a troubleshooting mode that can help you connect devices to the 2.4GHz network or allow older devices to connect.
You'll find this via the Settings tab:
Then select Troubleshooting and the top menu item My device won't connect
Choose the relevant option:
If needing to connect a device to the 2.4GHz network select Temporarily pause 5GHz
eero Settings tab - select Troubleshooting
eero Settings tab - Troubleshooting - select My device is 2GHz only
If either of the two troubleshooting modes gets your devices connected to the eero then all good. If it's a Wi-Fi interference issue then there isn't the option of manually selecting Wi-Fi channels as the eero will detect and select the best channels to use.
A signal strength issue is likely due to non-optimal placement of the eero. Ideally a single eero ought to be central to the household and placed mid way between floor and ceiling.  The eero app help is linked below and is via your Future Fibre MyAccount login. There's more guidance on placement of the eero device.
The eero Support Hub is your go-to resource for information, guides and Community support
Select here:
eero Support Hub
eero 6 and eero Pro 6 Help
eero - Setting up your eero
 eero app
eero - Problems connecting a device?
Message 3 of 4
What WiFi band are these devices connected to, the 2.4 or 5GHz bands?
Slow speed, intermittent dropouts, breaks in the signal or no signal on some or all devices or no internet access might be caused by Wi-Fi interference from other local networks, which can also lead to a permanent reduction in speed. No ISP can be responsible for your local environment, this is mainly a by-product of the popularity of Wi-Fi.
The next stage involves sending out a guide to you to help you get me some important diagnostic results so that I can analyse them for you and recommend changes to your router configuration to solve them.
