FAST 5364
iamisaid
Super Duper Contributor
Message 7 of 7
On Service Centre "My Router" it states that software needs updating. the router has
Version SG 4K10002816t, I have disconnected/reconnected the router but it has had no effect.
Could you please action a solution. Thank you Neil
6 REPLIES 6
Skynet_TX
Message 1 of 7
For info, my router updated last Thursday night, but the Service Centre still reported that I needed a firmware update until yesterday, so it looks like it just takes the Service Centre a few days to catch up and notice you are on the new firmware.
Message 2 of 7
You router definitely has the latest firmware version so it looks as though Service Centre is misreporting it. If you log into your router settings it will give you the firmware version there
Message 3 of 7
Hi Chris-TalkTalk  Thanks for update to software but Service Centre "My Router" still states that software needs updating,
                                   I have done a disconnect/reconnect but still no change.   Neil
Chris-TalkTalk
Message 4 of 7
Hi Neil,
I've checked again and can confirm that your router has now updated to the latest firmware version
Chris-TalkTalk
Message 5 of 7
Hi Neil,
The new firmware is being rolled out so, as Skytnet_TX has said, your router should automatically update
Skynet_TX
Message 6 of 7
Hi @iamisaid,
My router automatically updated from the version you are using to SG4K100136 (the latest version) on Thursday night, so you may find that yours will update by itself soon. However the support team here will also be able to push the new version out to your router when they return next week if required.
