Fast Modem DHCP
victorcc
Message 2 of 2
I am trying to set up static IPs on my new Fast Modem. I noted that the IP addresses 192.168.1.2 to 192.168.1.9 are not included in the table. Apart from  xx.2, does anyone know why this is?
I have changed the table to include these addresses, but before I reserve addresses as per my previous modem, it would be wise of me to check this out.
1 REPLY 1
Message 1 of 2
It is just that with the Sagemcom routers, the default IP address range of the DHCP server is .10 to .254. Of course, you can change it to start at .2 if you wish.
