on 12-01-2026 02:56 PM
Hi - anyone know how to enable Bridge Mode on the Sagemcom FAST 5364 modem router that comes with Fibre 65.
I've purchased a couple of eero 6e pro devices to replace inconsistent wifi extenders and eero suggest putting the modem/router in to bridge mode.
I've logged in the the admin GUI and poked around including in advnaced but can't see anything that mentions bridge or passthrough mode. I can see I can disable wifi but that's not what I should use is it?
I'm familiar with the use of SSH - I configure Unix web servers.
on 13-01-2026 11:20 AM
I understand and thank you for the information, @KeithFrench will look into this for you.
on 13-01-2026 11:19 AM
Thanks Mandisa but I have 2 eero because my existing wireless network doesn't reach the office in the back (a converted outhouse attached to the house) and the WiFi extenders I was using were inconsistent in performance.
I need the WiFi 6 mesh that the 2 eeros offer
on 13-01-2026 11:16 AM
@KeithFrench I was trying to set up the two eero 6 pro I purchased as per eero support. They recommend putting the routing functionality of any existing modem with built in router (like the Sagemcomm 5364) in bridge mode to make best use of the eeros as per this article https://support.eero.com/hc/en-us/articles/208276903-Bridge-Mode-and-Double-NAT
I've used double NAT for now
on 13-01-2026 10:57 AM
Thank you so much @KeithFrench
on 13-01-2026 10:56 AM
Hi @jgd1955
@Mandisa-TT has asked me to help you. No current TalkTalk router supports bridge mode, although they can be configured in a similar way. To save me having to read through every post, please can you summarise exactly what you are trying to achieve & I will tell you how to configure the router.
13-01-2026 10:14 AM - edited 13-01-2026 10:16 AM
You could put eero into Bridge mode and let the FAST 5364 handle routing, but you’d lose eero’s advanced features (like parental controls and security).
on 13-01-2026 10:12 AM
I understand.
What you’ve done—disable Wi-Fi on the FAST 5364 and run eero as router—is perfectly workable for most scenarios. The main drawbacks are with inbound port forwarding and some VPN/gaming setups.
on 13-01-2026 10:03 AM
I know this.
Bridge mode is available for the FAST 5364, but you would need to send a JSON-String, most probably via a POST request to the correct endpoint. I can't find any exact references to doing this
I've set up the 2 eeros I have using double NAT and disabled WIFI on the Sagemcomm.
I will reevaluate my options in September when my TalkTalk contract is due for renewal.
on 13-01-2026 09:01 AM
Hi @KeithFrench any suggestion on this.
on 13-01-2026 08:59 AM
Here’s what you can do:
Log into the FAST 5364 admin interface (usually 192.168.1.1).
on 13-01-2026 08:58 AM
On FTTC (Fibre 65), you still need the Sagemcom FAST 5364 because it handles the VDSL connection, so you can’t bypass it like with full fibre. That means:
on 13-01-2026 08:57 AM
The Sagemcom 5364 is both a modem and a router. The question was to put the router in passthrough or bridging mode as eero recommends. That can be done but TalkTalk are unable or unwilling to help with this.
Although not ideal my choices are to use double NAT mode or replace the Sagemcom with a more configurable third party DSL modem router
on 13-01-2026 07:02 AM
Thank you @ferguson
12-01-2026 07:10 PM - edited 12-01-2026 07:11 PM
You need a modem (or ONT) in order to use eero devices. Otherwise they just won't work.
on 12-01-2026 05:07 PM
Nambuso - very unhelpful as I clearly stated that I had Fibre 65 in the original question.
on 12-01-2026 05:04 PM
According to Gemini AI
on 12-01-2026 04:59 PM
There's no refernce to bridge mode in the official sagemcom manual https://www.manualslib.com/manual/2554778/Sagemcom-Talktalk-Fast-5364.html#manual
@jgd1955 After reviewing your account, I see that you are on the Fibre 65 package, and unfortunately, the eero device you're trying to connect to your Sagemcom FAST 5364 router is not compatible with this package. It is designed to work with the Full Fibre package instead. Since we've explored all other options for setup, this compatibility issue may be the reason we're unable to establish the connection.
on 12-01-2026 04:50 PM
There is no Bridge Mode in the Web GUI. Do you have a screenshot?
According to this thread there is no way to do this https://community.talktalk.co.uk/t5/Full-Fibre/Bridge-Mode-Sagecom-Fast-5364/m-p/3092290/highlight/t...
on 12-01-2026 04:27 PM
Please try the below steps to Enable Bridge Mode on Sagemcom FAST 5364
