on 11-01-2026 07:26 PM
I have recently upgraded from 'copper wire' to Full Fibre and TalkTalk sent me another WiFi hub which is identical to my existing WiFi hub but with an older firmware version.
The old version was SG4K100208 and its replacement is SG4K100174.
Why is this?
on 14-01-2026 09:54 AM
Thank you so much for the support @KeithFrench
on 14-01-2026 09:50 AM
Hi @JohnIsard
Both the 5364 (Hub 1) & 5464 (Hub 2) run the same firmware & should now be on V208.
on 13-01-2026 04:57 PM
We are glad to hear that, is there anything else you would like us to assist you with at the moment?
on 13-01-2026 04:54 PM
Thank you, that has satisfied my concerns. I will now return your old WiFi Hub in the supplied packaging.
on 12-01-2026 02:29 PM
@JohnIsard the versions update automatically. Your router will also update as time goes. Should you encounter faults please reach out for assistance.
on 12-01-2026 02:23 PM
This has not answered my question. Why does my new WiFi hub have an older Firmware version?
According to another post on here, Firmware Version .......174 actually has some issues.
on 12-01-2026 07:11 AM
@ferguson thank you for the support.
on 11-01-2026 08:10 PM
There you go then, you have your answer! 🙂
on 11-01-2026 07:38 PM
Further to my last post, I notice that they aren't identical Sagemcom routers because the later one has a VoIP phone socket. Furthermore hey have different Device Versions, the old one is "FAST 5364-3.T8" and its replacement is "FAST 5464-2.T4"
