What speeds should I be expecting with Fibre 65 Plus
terrythetucker
Message 4 of 4
What speeds should I expect to get on a fibre 65 Plus
Does 22 Mbps and download of 2.63 Mbps sound correct
3 REPLIES 3
Message 1 of 4
@terrythetucker are you experiencing slow speeds? does this happen on different intervals, or it is an everyday thing?
Phili
Philile-TT
Message 2 of 4
@Gliwmaeden2 thank you the support.
Phili
Gliwmaeden2
Message 3 of 4
FIBRE65 has 65mbps at the top end of the service, @terrythetucker, but averages can be quite a bit lower and actual speeds are specific to your particular line.
But those speeds, both down and up sound more likely for Fibre35.
So complete your community forum profile details and staff will be able to run a check on the line.
You'll need to be at home during the day for them to run tests.
Check what your contract says (it would have come by email when you joined / renewed) and running a test from the My Connection function in Service Status Dashboard should also indicate whether or not this is poor for your line.
To complete your details, go via your avatar; settings; add your Talktalk phone number or account number in Personal Information. SAVE CHANGES.
