on 12-01-2026 02:56 PM
Hi - anyone know how to enable Bridge Mode on the Sagemcom FAST 5364 modem router that comes with Fibre 65.
I've purchased a couple of eero 6e pro devices to replace inconsistent wifi extenders and eero suggest putting the modem/router in to bridge mode.
I've logged in the the admin GUI and poked around including in advnaced but can't see anything that mentions bridge or passthrough mode. I can see I can disable wifi but that's not what I should use is it?
I'm familiar with the use of SSH - I configure Unix web servers.
on 12-01-2026 04:06 PM
Hi - if I switch the WAN addressing type to Static where do I get my public IP address from? I surely can't retain the one assigned from TalkTalk?
I can, as you suggest, set my IPv4 DNS servers manually to Google's
The eeros don't have DSL modem capability (I'm on Fibre 65) so I will need to retain the Sagemcom for this functionality. The eeros will replace the wireless SSIDs on the Sagemcom.
on 12-01-2026 03:47 PM
Change DHCP Settings:
Finalize DNS Settings:
Turn Off Wi-Fi:
on 12-01-2026 03:33 PM
Hi Nambuso - when I log in I see 3 options See internet settings / See Wi-Fi settings and Manage My devices
If I go to Internet settings > Manage advanced settings I have links to TalkTalk Wifi Hub, Access Control and Internet connectivity
Internet connectivity gives me for IPv4WAN Addressing Type (currently set to DHCP other options are PPP or static), VLAN id, Public IP address, Mask and Gateway
I'm also able to change DNS settings in another tab.
TalkTalk Wifi hub gives me Device info, LAN IPv4, Light control, DNS, DynDNS, Route and Maintenance, none of which contain any reference to IP Passthrough or Transparent Mode.
Any other ideas?
on 12-01-2026 03:06 PM
Log In to the Admin GUI:
Find the Advanced Settings:
Locate Bridge Mode:
Disable Routing Functions:
Save and Reboot:
Reconnect the eero Devices:
on 12-01-2026 02:59 PM
Hi there @jgd1955 Thank you very much for reaching out.
