on 14-02-2026 07:48 PM
My WiFi is not working it was working fine this morning
I have reset, nothing has worked I have unplugged its flashes, then it gets stuck for a bit and then back to flashing. Need help.
on 16-02-2026 08:17 AM
Perfect!
on 16-02-2026 08:16 AM
Thank you so much for letting us know @Marnee
Thank you @KeithFrench it was a faulty router, I did change the cables and filter. But the new router worked instantly.
on 16-02-2026 08:15 AM
I have an engineer coming out today, thank you.
on 16-02-2026 07:06 AM
Thank you so much @KeithFrench
16-02-2026 07:05 AM - edited 16-02-2026 07:06 AM
Hi @Marnee I will be able to look into this for you, let me know if you still need help.
on 15-02-2026 11:28 AM
This sounds like a possible line or router issue. What happens if you move the router, via a new or known good microfilter, to the test socket? This is located behind the Master Socket's removable faceplate, if you have that type.
