Frequent LAN Drop Outs
Brock_and_Roll
Message 9 of 9
Hi all,
I have a Sagemcom FAST5364, live 200 yards from the exchange and get excellent download speeds from Talktalk and BT before them.
Since I switched from BT last year, I am getting frequent (say once every few hours) but short-lived connection drops on my LAN connections (PC & Smart TV) - this can happen at any time of day - even if I am doing a Zoom call at 3am so I know if is not a capacity or throttling issue. Wifi seems to stay on as I can use my mobile when the LAN connection is down.
Any ideas?  Need to fix this otherwise will alas have to switch back to BT Business
Thanks in advance
8 REPLIES 8
Message 1 of 9
Hi Brock_and_Roll
Brock_and_Roll
Message 2 of 9
OK - might be the router. As I said previously this issue has only arisen since switched to TT and obviously a new router.
Message 3 of 9
Thank you. I've re-run the line test now which is still detecting the same fault. Would you like us to send a replacement router for testing purposes to rule this out?
Brock_and_Roll
Message 4 of 9
OK I have done that
Message 5 of 9
Thanks for confirming. Would it be possible to connect the microfilter and router at the test socket so we can re-run the line test again please?
Brock_and_Roll
Message 6 of 9
Thanks for the reply.
Yes, there is a test socket
Message 7 of 9
I'm sorry to hear this. I've run a test on the line now which has detected a potential fault towards the property and the connection looks very unstable. Does the main socket have a test socket please?
Message 8 of 9
They aim to respond within 48 hours (Monday - Friday) excluding Bank Holidays, but if more urgent you can always try the Service Centre on 0345 172 0088. The posts are responded to in time/date order, oldest first. Please try to avoid posting on here until TalkTalk has responded to you, otherwise, this will just put you further down the queue.
