Broadband Router Won't broadcast an SSID
TeeCee23
Message 15 of 15
My router isn't broadcasting an SSID on the 5GHz band. I have been in touch with your support team, they have taken me through several steps and concluded that there is a system error. They have told me that I need to escalate the issue by posting the issue on this board.
TC
14 REPLIES 14
Message 1 of 15
Ok thanks for confirming. Yes please can the original router be returned.
Thanks 🙂
Message 2 of 15
Yes it did.
TC
Message 3 of 15
I'm glad to hear this. Did you receive a router returns bag?
Message 4 of 15
The new router arrived earlier today, I have connected it up and it works perfectly.
Should I return the old, faulty router to TalkTalk or just dispose of it?
TC
Message 5 of 15
Message 6 of 15
Yes, I will let you know how it compares.
Many thanks
TC
Message 7 of 15
Hi TeeCee23
No problem. The router is on its way, please allow 24-48hrs for this to arrive.
Debbie 🙂
Message 8 of 15
Yes please, that would be great.
TC
Message 9 of 15
Yes, I have done a full factory reset tree times using the pin hole reset for 10 seconds, but it makes no difference.
TC
Message 10 of 15
Hi TeeCee23
Ok, I can send a replacement router, would you like me to arrange this?
Message 11 of 15
Yes, I have done a full factory reset tree times, but it makes no difference.
TC
Message 12 of 15
Hi TeeCee23
Have you tried factory resetting the router using the pin hole reset for ten seconds?
TeeCee23
Message 13 of 15
Yes, it used to work bur stopped a few weeks ago. It's a Sagemcom TalkTalk Wi-Fi Hub. Device Ver: FAST5364-3 T8.
The serial number is REMOVED
TC
Message 14 of 15
Can I just confirm, did this used to work ok or has this never worked? Which router do you have please? (make and model)
