Frequent slow broadband speed
Chris_J
Message 20 of 20
Over the last several weeks I've been getting frequent slow broadband speeds (only download, upload is always pretty good at 11.5mbps)
It coincides with me upgrading my package to Fibre65 towards the end of March, prior to this it was never a problem, I don't know if that's a coincidence or there might be a connection?
I've tried all the usual fixes, disconnecting devices from the wifi, restarting the router, switching off for 30mins, doing a factory reset, and although it does tend to come back at around 40mbps it will gradually drop down again to 2/3/4mbps.
I've also tried a wired laptop to the router, and had the same slowness.
When I've tried the line test on the TalkTalk website, it says an issue is suspected, and goes into another test, but that one always comes back as ok and I need to check my devices.
So it feels like there might be an issue somewhere?
Thanks, Chris.
19 REPLIES 19
Message 1 of 20
Thanks for the update. Can I just confirm, where did you read this?
Message 2 of 20
Just read that it's a wider issue in my area, so still plan to return the old router 👍
Thanks,
Message 3 of 20
Hi, new router has been behaving well over the last couple of weeks, and I was planning on returning the old one at the weekend, but today since lunchtime I've had a solid orange light again, so not sure what has happened there?
Thanks,
Message 4 of 20
Message 5 of 20
Hi, new router is now connecting 👍
Will keep an eye on it over next few days and report back.
Thanks,
Chris.
Message 6 of 20
Yes please, if you could give it another try that would be great.
Message 7 of 20
Morning, I left the router plugged in over Saturday night till about midday on Sunday, but still solid orange light. Since then I've gone back to the first one.
Do you think it's worth me trying again with the new router today?
Thanks,
Chris.
Message 8 of 20
Hi Chris,
How are you getting on, is the replacement router still not connecting?
Message 9 of 20
Hi, router received this afternoon, thanks for the speedy delivery.
But I've connected up this evening and I'm seeing a flashing orange and white light for several minutes and then solid orange - I tried a factory reset but didn't make a difference.
Thanks,
Chris.
Message 10 of 20
Thanks Chris, I've ordered the replacement router, it should be with you within a couple of working days
Message 11 of 20
Hi Chris, have just done that now.
Thanks,
Chris.
Message 12 of 20
Hi Chris,
Could you just add the account holders name to the private notes section of your community profile and we'll arrange to send a router
Message 13 of 20
I don't unfortunately, but happy to be sent an alterative for testing, and will return one as appropriate.
Thanks,
Chris.
Message 14 of 20
Ok, do you have an alternative router that you could test with please? If not then we can send a replacement router for testing purposes to rule this out. We would also send a router returns bag so that one of the routers can be returned.
Message 15 of 20
I've found it doesn't always increase immediately, but after it's been rebooted and left for up to 30mins-ish, it does tend to be back up to speed for a time, until it eventually drops back again.
Thanks,
Chris.
Message 16 of 20
I'm sorry to hear this. I've run a test on the line which hasn't detected a fault. Does the throughput speed always immediately increase after the router has been rebooted?
Skynet_TX
Message 17 of 20
Interesting, as I had a similar issue with a DG8041W a while back, after a router restart I'd get my normal download speed (37 ish), but within a day or so it would drop to 4 or 5. At the time I didn't know it, but I had a subtle fault on my phone line back then, so I do wonder if the DG8041W might be a bit sensitive to some sort of line faults that might then cause the speed to drop.
The support team here will be able to help more tomorrow, they will also be able to do more checks on your line to see if they can identify any potential fault.
Message 18 of 20
Hi, looks like it is a DG8041W.
Thanks,
Chris.
Skynet_TX
Message 19 of 20
Hi @Chris_J,
What model of router do you have ?
The support team here will be able to take a look at this, they will hopefully be able to respond tomorrow.
