Home safe stopped working after engineer visit.
Darren19701
Message 35 of 35
We had an engineer install full fibre broadband to our property on Friday.
He put in a new terminal box and then connected it to our wifi hub using a cable supplied by Talk Talk.
Since then the home safe setting have not worked at all.
I contacted TT and they took me through all sorts of changes to our computers but nothing made a difference. It seems obvious that the change to fibre is the issues, but TT aren't being very helpful. I can expect a call from an engineer, but probably not until after Christmas.
This is too long to wait for me, so does anyone have any idea what might be happening?
I thought it might be that the router is pointing at a new dns, but the dns is still 79.79.79.79
It's very perplexing and upsetting.
Thank you.
34 REPLIES 34
Message 21 of 35
I've added contact details onto my profile.
Apologies for posting twice, but the initial message on Fibre was being ignored.
Message 22 of 35
OK thanks martswain, I know the OP won't have telephone number but the other info may be useful 🙂
martswain
Message 23 of 35
@Chris-TalkTalk the OP, @Darren19701  has had FULL FIBRE installed so they will not have a phone number unless part of the VoIP trial.
They have also opened the same issue in the FIBRE board here
https://community.talktalk.co.uk/t5/Fibre/Home-Safe-Not-Working-Since-Full-Fibre-Broadband-Installed...
Maybe this should be moved to the FUTURE FIBRE board.
Message 24 of 35
OK thanks.
  • Name
  • Telephone number
  • Alternative contact number
Darren19701
Message 25 of 35
Yes. Definitely using talk talk.
Message 26 of 35
Could you just confirm that you're definitely accessing the Internet via your TalkTalk router and not your mobile phone network?
Message 27 of 35
Yes. For example bet365.com is a gambling site that should be blocked but can be accessed via three different laps tops and two phones.
Message 28 of 35
And you can access sites that should be blocked, on more than one device?
Message 29 of 35
I have a sagemcom wifi hub router.
Message 30 of 35
And you have the Sagemcom router?
Darren19701
Message 31 of 35
Yes. I've tried that. Does not make a difference. Still no protection from harmful sites.
Message 32 of 35
OK thanks, have you tried switching it off and back on again in My Account? If you haven't then can you give this a try and let us know how you get on
Message 33 of 35
Hi Chris. Yes it is.
Chris-TalkTalk
Message 34 of 35
Hi Darren19701,
Is HomeSafe enabled in My Account?
